Can I use different O2's on each side?
Old Apr 19, 2004 | 10:43 AM
bad1LEz's Avatar
My drivers side O2 is bent upward due to lack of wire length. Going to put an extender on and was wondering if I can put a new AC delco sensor on that side but leave my Bosch on the pass. side? Are two diff. brands compatable or do I need to make both banks the same. These sensors have <2000 miles on them.
Old Apr 20, 2004 | 09:09 AM
Brent94Z's Avatar
Super Moderator
Using two different O2 sensor brands should not be an issue.
The issue I recall with O2 sensors is that the non GM O2 sensors are hit and miss in that some seem to work OK and some don't. Since you already have the Bosch O2 sensors on your car and they are working good, you shouldn't have a problem putting one GM sensor on there.
Good luck!
Old Apr 20, 2004 | 10:32 AM
bad1LEz's Avatar
Thanks man. I thought it wouldn't matter as long as the current one is working correctly. Just wanted piece of mind from someone who knows for sure.
MikeWhitener
Aug 2, 2015 06:17 PM
hcarrickz3
Jul 21, 2015 08:46 AM
Fastbird93
Jul 11, 2015 04:37 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
