motor mounts..rubber or poly..solid or stock??
Old Apr 20, 2004 | 07:04 AM
bad1LEz's Avatar
I have a BAD vibration and I think it is breaking out the collector donuts causing the headers and Y to vibrate together. I have an ES poly tranny mount, should I also get the ES poly motor mounts to keep everything poly and the same. I read about solid and the stock mounts, any difference in these, or what should I get? I think pep boys here has the black ES poly's. Thanks for all the help.
I need to fix the vibration before I loose some fillings.
Old Apr 20, 2004 | 08:52 AM
CrippleFightin's Avatar
Poly bushings and tranny mounts cause more vibration, that ES tranny mount did the same thing to my A4 back in the day when I had it. When getting the bushings, get the poly/rubber ones and there will be less vibration.
Old Apr 20, 2004 | 10:43 AM
bad1LEz's Avatar
Is there such a thing as solid mounts and just stock mounts, or is there just one kind of mount for the LT1? Where would I find the rubber/poly mounts, Summit?
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
