Can I use CAM 2 leaded gas.
Old Jul 11, 2003 | 09:36 AM
JAFO1994's Avatar
The only gas available with high octane is Cam 2, but it's leaded. I need to verify my knock as false. I want to run about 4 gallons. Will this harm anything being leaded? I can't find unleaded high octane any where. I'm at the point of adding 1 gallon of toluene to 4 gallons premium.
Old Jul 11, 2003 | 09:46 AM
Buttercup's Avatar
Lead will eventually destroy the O2 sensors and Cat. People do get away with using a little bit usually. If you must use it only put a bit in the gas tank, burn it up quick and fill the tank with good unleaded afterwards and you probably won't have any problems.
Old Jul 11, 2003 | 10:48 AM
rskrause's Avatar
Moderator
Just running 4gal for testing should not harm your Os sensors. Not as sure about the cats though.
Rich Krause
Old Jul 11, 2003 | 10:50 AM
IrocManiac's Avatar
Just running 4 gallons you should be ok....if you make a habbit out of it you'll toast the O2 sensors and your cat(s) will become clogged fairly quickly...
PCLZ28
Apr 29, 2015 11:56 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
DetroitZ28
Feb 13, 2015 07:33 AM
Alex Barnes
Jan 24, 2015 10:21 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
