Can I use 95 headers and y pipe on my 97?
Old Oct 16, 2004 | 10:50 PM
remaxracer45's Avatar
I have the madwolf obd1 conversion and was wondering if I could use the 94-95 slp shorties and y pipe on my 97Z?
Old Oct 16, 2004 | 10:55 PM
Spinner's Avatar
Re: Can I use 95 headers and y pipe on my 97?
Yes, so long as you use the Y-pipe. You'll need an S pipe to go from the Y pipe to the rest of your exhaust, because the two model Y pipes come out in a different place, your local muffler shop could fab one up pretty easily.
Old Oct 17, 2004 | 12:28 AM
Z95m6's Avatar
Yep just like Spinner said. You can use the 94-95 headers and y-pipe on your car. You will just need to get an S pipe made to mate the ypipe to the catback. SLP sells an S pipe but you can just get one made too. If you're still running the stock catback you could just order a 94-95 aftermarket catback exhaust and it will all go together with no S pipe then.
Old Oct 17, 2004 | 10:31 AM
Hawk's Avatar
also you guys forgot one thing, you need the smog adapters so you can attach the stock fittings to the 94/95 headers. www.thunderracing.com has them when I needed them, it is not listed on their website you'll have to call or email.
Brian
Old Oct 17, 2004 | 05:56 PM
I've gutted all the emissions off it. anyone have a template of what the s pipe needs to be? This way I could just take the demensions down to exhaust pros and be done.
Thanks a ton you guys are awesome
Shawn
Old Oct 17, 2004 | 10:31 PM
The s pipe kit is it slp part#30045?
TitoPR221
May 26, 2015 12:20 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Russ95Z28
Apr 23, 2015 01:55 PM
Queens94z28
Mar 23, 2015 08:06 AM
alphaauto
Jan 23, 2015 07:42 AM
