can I test a cat (cloged or not) off the car-found one in garage
Old Apr 24, 2003 | 04:17 PM
D James's Avatar
I found one and was wondering if there is any way to test it, like run compressed air through it. I believe the answer will be no, but want to double check. I am installing some on my longtubes, and if I can use this old one then I can save some money, but I have no idea where it came from or if its bad. I don't care about passing emissions, just visuals, but I want it to flow well too. Should I just buy a new one, I found a good priced soundcat 3 inch for 50 bucks new+ shipping
Old Apr 24, 2003 | 04:33 PM
D James's Avatar
Well I was just looking at it, and one side of the honeycomb is dark from exhaust and the other side is white, not sure if this means anything.
Old Apr 25, 2003 | 12:28 AM
Lt1t56's Avatar
A good cat you should be able to look through and see light from the otherside, the light will be dim but should be able to see through the honeycomb.
Old Apr 25, 2003 | 09:04 AM
RENE95Z's Avatar
"I don't care about passing emissions, just visuals, but I want it to flow well too. "
If that is the case, just gut the cat and you are set.
Old Apr 25, 2003 | 09:07 AM
scoobysnax83's Avatar
Einstein joined the board..... Good Point!
naaz90
Jul 27, 2002 08:22 AM
