Can I run NO Y-pipe for a few minutes?
Hey all, I'm trying to eliminate my cats as my possible problem with how crappy my car runs, can I take it off for a 5 minute drive, or will it run just as horribly with no pipe/o2's?
Re: Can I run NO Y-pipe for a few minutes?
If you have long tubes i would say it would be ok.. but no not if you dont have headers, shortys or mids.. no.. long tubes would be pushing it.. backfire from hell.. and with shortys could be dangerous.. the cold air coming back towards the motor could hurt it badly..
I say DONT do it. Your rear O2's will go nuts and it wont prove anything. Plus its possible it would backfire flames out under the hood ...
My car was OBD1, so when I did my long tubes I drove around with open headers a few times ( Total of about 10-15 miles ) Did no harm, was obnoxiously loud ( The way I Like It
), and was incredibally hard to diagnose any strange noises )
However, if you did an OBD1 conversion, or have rear O2 sims, unbolt that bitch and give it a try ... If the car is progressively getting less and less power and can barely move itself, it has somewhat higher mileage ( Say over 70 ) then id say the Cat is a good possibiltiy
), and was incredibally hard to diagnose any strange noises ) However, if you did an OBD1 conversion, or have rear O2 sims, unbolt that bitch and give it a try ... If the car is progressively getting less and less power and can barely move itself, it has somewhat higher mileage ( Say over 70 ) then id say the Cat is a good possibiltiy
I have a 95 so its OBD1 and I have long tubes. But I ran open header for a few months. I even made a trip to Knoxville in the dead of winter. As long as you have long tubes, I would say you are fine to run open header. May just run open loop, but it wont cause any permanent damage.
Actually, I may get lucky and the dealer will replace them under warranty again, happened earlier this year and it still has under 70K miles.
Jan 23, 2015 01:13 PM
