can I run 7 Cylinders?
Old Apr 20, 2006 | 11:36 PM
Heatmaker's Avatar
Advanced Member
I just finished checking my Spark plug wires. Ever since I found a burnt plug end, I made it my business to search for others. I now fount one completely burntout plug wire. I ended up damaging the end of it removing the plug so I had to shorten it a bit and put on a new boot to hold me through. The bad part is that now the wire is too short. I messed up by about half an inch. My question is will it be ok to run the car as is with only 7 cylinders down to the auto shoppe tommorow where I can fix it... or what?
Old Apr 20, 2006 | 11:45 PM
KillWhitey's Avatar
Re: can I run 7 Cylinders?
It will run like crap
edit: if it runs at all
Old Apr 20, 2006 | 11:50 PM
urbaNHunter44's Avatar
it will run, but it won't be good at all for your car. Get a ride from someone.
Old Apr 20, 2006 | 11:51 PM
Daniel6718's Avatar
yes but i would say pull the injector wire as to not dump gas into the exhaust and foul the o2 sensor that costs bucks....and your car will think its rick if you dont unplug this and cause all the other cylinders to lean out...it should be alright dont do it for long though...
Old Apr 21, 2006 | 12:01 AM
LiENUS's Avatar
Your car will begin thinking its lean at that point to... the best thing would be to pull the intake and pull the lifters for that cylinder...
Old Apr 21, 2006 | 12:06 AM
johnny3986's Avatar
Pulling lifters for that cylinder? Pulling an intake? Get a buddy's ride or grab a bike if you are super concerned.
Old Apr 21, 2006 | 12:14 AM
sprayedtransam's Avatar
for sure. A car will run on 7 cylinders, anyone ever had a bad injector or any other type of dead miss? Just be easy on it, and don't drive it any more than you have to.
Old Apr 21, 2006 | 12:45 AM
Daniel6718's Avatar
i dont see why it would think its lean if you pull the injector? possibly slightly...but i think its better than dumping gas...anyways yes ive had a miss beofre and driven it almost 2k before i could find the dam thing out(i have a big cam so miss kinda blends in with the choppyness)
it will be fine...i beat on it like this also...(wish i hadent) but from your house to your mechanice youll be fine
Old Apr 21, 2006 | 01:14 AM
johnny3986's Avatar
I was just talking about it was a lot easier to catch a ride than do all that. That is just my $.02..
Old Apr 21, 2006 | 01:50 AM
96ta(nick)'s Avatar
I ran a 13.7@103 on 7 cylinders.
Old Apr 21, 2006 | 02:18 AM
HungryT/A's Avatar
Running on 7 cylinders, with one cylinder pumping fuel but no spark, is a big nono in my opinion. The fuel will wash off the oil from the cylinder wall, and you will end up with broken rings or scuffed cylinder.
Old Apr 21, 2006 | 02:25 AM
MENEGRANDE's Avatar
get a [edit] bus man! or a cab...don't risk it...
Note from Moderator: Do not override the language filter.
Old Apr 21, 2006 | 02:49 AM
Daniel6718's Avatar
am i the only one that read the original post, he asked
yes fpr taht short distance yes, he cant catch a ride to the shop to work on his car if his car aint there....
Old Apr 21, 2006 | 07:06 AM
Javier97Z28's Avatar
Moderator
LOLOLOLOLOLOL yah that'll get him to the auto parts store...
Old Apr 21, 2006 | 07:09 AM
Heatmaker's Avatar
Advanced Member
What!?!
