Can I roll miles forward?
Old Sep 22, 2003 | 03:21 PM
2nd2none's Avatar
I screwd up my speedo while putting white face gauges on, I am gonna buy another Speedo cluster but it has lower miles, can I advance the miles to match mine?
Old Sep 22, 2003 | 04:04 PM
madwolf's Avatar
You can, but it's easier to just swap the odometer unit.
Old Sep 22, 2003 | 04:12 PM
2nd2none's Avatar
Question
I messed up the old one already cuz I was gonna put the new one. Do I just turn them forward???
Old Sep 22, 2003 | 04:17 PM
chasmanz28's Avatar
pm sent, check your email
madwolf's Avatar
How could you mess up the odometer unit while installing gauge overlays? I understanding messing up the pins or some other things, but the odometer unit can be removed separately from the cluster. All you need to do is remove the 6 or so screws from the back of the cluster, pull the board and remove a couple of screws that hold the odo in place.. oh, and undo the odo's electrical connector. That's it.
No, it will not just roll forward. At least I couldn't do it. I once had a bad cluster and was playing with it just out of curiosity. I was able to change the values, but not to a specific number I wanted. I could go from like 50,234 to 72,546 but not 72,000 or something like that. It's a PITA to mess with these things, that's why I said swap it...
Old Sep 22, 2003 | 07:50 PM
2nd2none's Avatar
Thanx for all the help. I just bought another similar.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
