Can I reuse my header gasket?
Old Nov 8, 2004 | 01:37 PM
Cmr0z28's Avatar
I just swapped gaskets this weekend (Fel-Pro 1406's), and I need to take off the driver side header to bang in the floorboard due to clearance issues with the collector. Can I re-use the driver side gasket? The motor has been through 5-6 heat cycles since the swap.
Old Nov 8, 2004 | 01:39 PM
1 Nasty Bird's Avatar
Re: Can I reuse my header gasket?
if it comes off in 1 peice id reuse it, i wouldnt count on that though.
Old Nov 8, 2004 | 01:41 PM
25th_Trans's Avatar
I'd just go through summit and order a set of copper gasgets for 28 bucks
Old Nov 8, 2004 | 01:51 PM
Cmr0z28's Avatar
Fel-Pro's are pretty good gaskets. My old ones leaked all over due to me not re-torquing the bolts, and they came out in one piece.
Old Nov 9, 2004 | 04:08 AM
i had the fel-pro 1406s on my LT1 caprice, with stage 8 bolts, 3-4 days later, half the gasket material blew off and dissintegrated, and about a 1/4 of the aluminum was missing too. (I drove about a week with the leak befor ei could get in to fix it)
dylan1303
May 22, 2015 12:24 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
