Can I put a 97 Wiring harness/Computer in my 95 and be ok?
Old May 15, 2005 | 10:28 AM
OBDIICamaro's Avatar
I have a tuned computer that I want to use and a harness, can I run this in my 95 if the setup is from a 97?
Old May 15, 2005 | 10:38 AM
kainZ's Avatar
Re: Can I put a 97 Wiring harness/Computer in my 95 and be ok?
They're the same number of pins, as you know.. but I'd be weary, as the 95 (OBDI) doesn't have many of the sensors that the 97 (OBDII) has.. I wouldn't even be suprised if some of the pins were used for different purposes on the 95 when compared to the 96/97.. I'd definetly wait for a response from shoebox or injuneer or someone with more experience before you try it..
Edit: I think I misunderstood your post the first time I read.. I was thinking you just wanted to use the 97 harness... No, the 97 computer will not work on the 95, as you're missing lots of the extra OBDII sensors on your 95 (OBDI) car... If it ran at all, I'm sure it would run like $h!t.. and you'd have an eternal SES light.. but I wouldn't be suprised if it didn't even run..
Old May 15, 2005 | 11:18 AM
ForceFedZ's Avatar
96 and up model cars (OBDII) use a crankshaft position sensor. If you install this on a 95' my thoughts would be that it wouldnt even run.
Old May 15, 2005 | 04:47 PM
OBE1 95Z28's Avatar
Beside missing the crank position sensor, the 97 computer will be looking for rear O2 sensors (after the cat) and a different knock sensor valve. I'm sure there's additional differences too.
Old May 15, 2005 | 08:42 PM
Ok I mistyped alittle.... I have a complete 97 drivetrain going in with 97 computer, harness, engine and trans. Will I be ok running this stuff in a 95 since Im technically replacing everything minues the main power harness for lights/blinkers, etc..etc..????
Old May 15, 2005 | 08:57 PM
97s10ondubs's Avatar
Kk number one the car WILL run w/o the cps(crank sensor) it will just throw a code, i lived this first hand, it is just for finding missfires. Rear o2's can be programmed out of a OBD2 car, which i also did b4 going to OBD1.
Old May 15, 2005 | 11:53 PM
Old May 16, 2005 | 05:35 AM
30696bird's Avatar
It'll be fine.
Old May 16, 2005 | 09:11 PM
Ok thanks
PCLZ28
Dec 24, 2015 05:19 PM
eazyZ
Mar 1, 2015 07:12 AM
Fatdog2
Feb 13, 2015 08:19 PM
jayvar
Feb 2, 2015 10:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
