Can I drive with 4 of 5 lug nuts on?
Old May 26, 2003 | 01:58 PM
DPassion's Avatar
Question Can I drive with 4 of 5 lug nuts on?
Wondering if I can drive with 4 of 5 lug nuts on temporarily since I just broke off a stud. Whoever put on my wheels last, cross-threaded one of the lug nut and in my attempt to remove the lug-nut, I broke off the stud. How "smart" would it be to drive with 4 of 5 lugs nuts on ? Thanks!!!
Old May 26, 2003 | 02:03 PM
Derrick Redd's Avatar
It should be ok for temporary use.
Old May 26, 2003 | 02:06 PM
faded93bird's Avatar
sure you can theres on prob
BTW Mustangs only came with 4 lugs for a while so you should be fine right
Old May 26, 2003 | 02:44 PM
Larnach's Avatar
NO!
Don't go on the freeway like that, why the hell would you do that anyways, there like $0.89 a peice from AutoZone for the studs/nuts, you can get locks for like $9.00 there.
Old May 26, 2003 | 03:01 PM
96BlackTA's Avatar
You'll be fine so long as
A:The other 4 are properly torqued
B:You don't do anything crazy
C:It's only temporary having 1 less lug nut just increases the pressure put on the others
Old May 26, 2003 | 03:46 PM
Phatcaprice's Avatar
The hobbystock guys around here are so broke they sometimes go with 3 lug nuts, ON A DIRT CIRCLE TRACK!!!
"risk your life" RACING!!!
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
Fatdog2
Feb 13, 2015 08:19 PM
Moshbmx1
Jan 20, 2015 03:27 PM
squarehead
Nov 21, 2014 08:02 PM
sseeya
Aug 8, 2002 11:37 AM
