can i do low 12's
Old Apr 28, 2003 | 11:41 PM
cobraklr96's Avatar
can i do low 12's
quick question guys, and gals. i have a 96ss with t-tops its a A-4. mods are hooker long tube headers with no cats going into a slp lm, mezi w/p, stb,sfc,panhardbar,lcas,troque arm. and a vortec sq trim with 6 pounds of boost(charger wating to be installed)
what should i do xe grind i think it is 230/236 on a 114
or a vig 2800 stall converter.
also do you think i will hit low 12's with either choice.
the tire as the nitto 275/45/zr17 extremes all the way around
thanks to all tim
Old Apr 29, 2003 | 12:13 AM
neil350's Avatar
Re: can i do low 12's
You sort of want the converter on that big of a cam, I mean that isn't a 305 or hot cam were you will slide with tunning. Lets put it this way, no cam, no blower but all those mods, you should do 12s n/a. Cam and converter, I can't see why that car couldn't do 11s. Just in all honesty though, sort of wait for the converter till you can afford a good race rebuild, which is about 900 providing you drop it your self and bring it to them. With the blower, that stock 4L60E might very well go out.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
