can i delete or no?
Old Mar 23, 2010 | 11:59 AM
StangCrusher350's Avatar
can i delete or no?
on my 94 what are the valves called that stick out the top of the exhaust manifolds?? I cant break them out of the manifold, and i was just going to order new to put into my headers. Or can i delete these?? if i can delete them, what all is included in doing so? If you dont wanna tell me, will shbox have a diagr-am?
-thanks guys
Old Mar 23, 2010 | 12:08 PM
RamAir95TA's Avatar
Deleting them would mean deleting the AIR injection system. You'll need to remove the AIR pump, all subsequent lines, and plug the fitting on the intake ducting with a vacuum cap. One of the tubes will need to be destroyed in order to remove it (the one that crosses over under the timing cover).
Old Mar 23, 2010 | 12:12 PM
Are there any harmful backdraws to deleting all this?
thanks again..
the delete sounds simple enough.
Old Mar 23, 2010 | 12:21 PM
RamAir95TA's Avatar
thanks again..
No drawbacks whatsoever really. Make sure there is a good fuse in the system and you shouldn't get an SES light.
The plugs on the exhaust manifolds are an M22 pitch. You'll need an appropriately-sized pipe plug (or oil drain plug).
Old Mar 23, 2010 | 02:26 PM
thanks ram. just to clarify one last time, the only plugs that need to be plugged, are the ones that connect to the exhaust manifolds, or headers, and the one on the intake manifold. the rest of the hoses can just be disconnected and no harm done correct?
Old Mar 23, 2010 | 02:39 PM
RamAir95TA's Avatar
It's not on the intake manifold, it's on the intake ducting. Other then that, yep!
Old Apr 29, 2010 | 11:48 AM
khojo16's Avatar
i just removed all of this yesterday, and had to take small black plastic vaccuum lines off....one connected from the air valve attached to the hose for the air pump and connected to a black plastic part with a grey cap above the coil. do i need to cap that off?? also, removed EGR and there was a line that ran from the EGR valve to another plastic part on driver's side rear head area. do i need to cap that off as well?
Old Apr 29, 2010 | 12:16 PM
khojo16's Avatar
never mind, answered my own question. those parts im talking about are the AIR vacuum solenoid and the egr solenoid. both can be removed.
Old Apr 29, 2010 | 01:24 PM
SnakeOiler's Avatar
You need to plug any open vacuum ports.
thanks again..
You may not pass a visual emissions inspection.
Old Apr 29, 2010 | 01:34 PM
khojo16's Avatar
yeah i had already plugged the opening on my cold air intake, and the vacuum port on the intake manifold where the "T" for the egr solenoid and vacuum solenoid came from.
Old Apr 29, 2010 | 05:26 PM
The confusion results from the fact that you (khojo16) have a 96, with the vacuum lines, and the original poster has a 94, that doesn't have the vacuum line associated with the AIR system. It gets even more confucing if a 95-97 had the "AIR pump recall" done. That added a vacuum line. But the recall did not apply to 94.
stylin99
Feb 3, 2016 02:24 PM
tnmotown
Aug 10, 2015 11:52 PM
guest74777
Mar 25, 2015 10:30 AM
alex5366
Mar 8, 2015 11:32 AM
NVMYTA
Nov 23, 2002 06:04 PM
