can I convert to 95 - 97 oil pressure sensor?
Current oil pressure sensor is down by oil filter. Building a 383 with a '95 M6 wire harness and wanted to know if I could get the sensor that mounts next to EGR valve. I would rather replace into same position but I heard that the 95 wire harness won't reach down that far. So:
Can I install an oil pressure sensor on the back of my current manifold? I know this one uses the 1/8" threads.
Will the 95 M6 wire harness reach far enough to install a new sensor above the oil filter where it currently sits?
Jul 4, 2005 05:00 PM
