can I change the waterpump seal with the timing cover still on
Old Jun 12, 2003 | 06:17 AM
D James's Avatar
just finished up on my cam install, everything went very smoothly, in fact so much easier than what I thought it would be, except for the rain that made it a 5 day project The car runs great except I have a stream of oil coming out somewhere up on top of the timing cover, I assume the distributor one is ok, so must be the waterpump seal just pouring out the oil. So I can I change that seal without yanking the cover off, I found that to be one of the hardest part of the job, it wouldn't be bad, but dropping the oil pan in front sucks, since the bolts are so out of reach. If I must remove the cover should I just replace all the seals for peace of mind that they won't leak anytime soon, or do they last a long time.
Old Jun 12, 2003 | 09:19 AM
D James's Avatar
well I just went through every possible post and found out you can remove and install those things without taking the cover off
Old Jun 12, 2003 | 09:24 AM
That is exactly the way you do want to do it.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
