Can I change the steam pipe seals with the engine in the car
Old May 1, 2009 | 08:28 AM
  #16
meissen's Avatar
Originally Posted by stephenpen
The 2 seals cost me $28 at the dealer. How can PONTIAC be going out of business when they can sell two rubber washers for nearly $30.
I could only get the passenger side so I'll save the driver side for a rainy day.
because it cost them 26 to import them from mexico.
Old May 1, 2009 | 10:03 AM
  #17
R_ADKINS80's Avatar
I bought those rubber washers at the dealer for less than $25 for all 4 of them to do both banjo bolts???? Dunno why you had to pay so much.....I'd find another dealer. p/n is 10108689
Old May 1, 2009 | 10:09 AM
  #18
Ian marshall's Avatar
Try asking at you local pnuematics supplier for a dowty seal (English name) they are basicly a steel washer with inpregnated rubber that will seal fine and should cost about a dollar each
Old May 1, 2009 | 10:53 AM
  #19
stephenpen's Avatar
I'm from Canada so everything to do with cars cost more. They were $12 each before taxes and yes they are a dealer only item.
Old May 6, 2009 | 04:34 AM
  #20
The dowty seals are not designed for a specific application they are a hydraulic/ pneumatic seal that will work on the steam pipes on the back of the heads on the car, you may need to shop around a bit, but they will save you a fortune
Old May 6, 2009 | 06:44 AM
  #21
You can buy comparable seals from NAPA under part # 730-2922. Cheaper.
Old Oct 9, 2009 | 10:38 AM
  #22
FirstGenZq8's Avatar
bringing this thread TTT. shoebox, do you happen to know NAPA's new revised part # for these seals?
Old Oct 9, 2009 | 11:46 AM
  #23
No, but others have found the same type seals in the "Help!" section of a lot of auto parts stores. They are typical oil/hydraulic/ac seals used in the industry.
Old Oct 9, 2009 | 03:45 PM
  #24
Rich2279's Avatar
I bought the seals from NAPA in August for $1.29 each. You will need 4 of them. The part # on the invoice is 704-1093.
Old Oct 9, 2009 | 05:45 PM
  #25
JAKEJR's Avatar
I recently had to replace the passenger side seals on my 96 LT1 Vette and it was a pure nightmare to get the bolt started. Getting it off wasn't all that bad, once a bundle of electrical wires going through the firewall were moved, but starting the bolt again was a REAL PIA.
Of course, different model cars may have different issues; those were just mine.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
CaRParts102
Dec 6, 2014 08:45 AM
USAirman93
Nov 24, 2014 03:37 PM
The Seer
Nov 20, 2014 06:32 AM
Don 97 SS
Jul 11, 2005 08:50 AM
Jul 4, 2005 05:00 PM
