can i change a 96 OBD2 to an OBD1 pcm?
Old Nov 22, 2007 | 01:11 AM
mvvette97's Avatar
I was told that I can but I haven't been able to find any info on this. Can somebody help me out on this? thanks
Old Nov 22, 2007 | 01:38 AM
SS Joe's Avatar
All you need is a 94-95 PCM and the matching knock sensor that screws in the side of the block.
Old Nov 22, 2007 | 01:39 AM
mvvette97's Avatar
cool, that sounds easy enough. So the plugs on the pcm is the same?
Old Nov 22, 2007 | 01:44 AM
SS Joe's Avatar
Yes, its a plug in deal. You'll lose a little coolant when you take the knock sensor out (pass side of block), but if you are ready with the new one you can stick it in quick and not even have to drain the coolant. The whole thing will take about 10 minutes.
Old Nov 22, 2007 | 02:09 AM
WS6T3RROR's Avatar
Solder a resistor in the pcm and skip the knock sensor swap. A resistor is alot cheaper than a knock sensor, and if you frag your pcm you wont be on foot cause you can plug your old one in and go. do a search in the pcm and diagnostic section, i have done this several times and never had a failure.
However, it wont work with either of the ls cars you have in your sig.
Old Nov 22, 2007 | 02:37 AM
mvvette97's Avatar
ok thanks. It's for a 96 firebird.
Old Nov 22, 2007 | 02:59 AM
SS RRR's Avatar
emissions requirements?
Old Nov 22, 2007 | 03:50 AM
SS Joe's Avatar
Probably not a concern in Iowa.
Old Nov 22, 2007 | 09:53 AM
mvvette97's Avatar
Nope, no emissions here
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
nikolt1
Feb 27, 2015 09:10 PM
Jul 4, 2005 05:00 PM
