Can I block off inlet and outlet for heater at the water pump?
Old Nov 8, 2008 | 12:26 PM
94SLUG's Avatar
Will this affect how the pump works? Cooling issues? I want to block it at the pump....
Old Nov 8, 2008 | 01:26 PM
Yes, you can block it.
Old Nov 18, 2008 | 01:41 AM
94GreenMachine's Avatar
How would you recommend going about that?
thanks,
Old Nov 18, 2008 | 07:01 AM
thanks,
You could pull out the pipes, tap the holes and put tapered pipe plugs in them.
Old Nov 18, 2008 | 09:58 AM
kylersaulsbury's Avatar
I welded all of the outlets on my pump. Had the local speed shop do it, and he basically just drilled the pipe out and turned down a piece of aluminum to fit the hole and welded it in.
But i think the top oulet by the thermostat is a thermostat bypass so i've just been running a restrictor instead of a thermostat. It runs fine stays around 170-180 never hotter.
Old Nov 18, 2008 | 10:09 AM
cammed SS's Avatar
I blocked mine off using 5/8 rubber caps with adjustable hose clamps. Worked just fine.
Old Nov 18, 2008 | 06:13 PM
kyle88transam's Avatar
I used a small freeze plug in place of the pipe.
Old Nov 19, 2008 | 03:14 PM
sn8ke eatr's Avatar
i had the same question.. cool.. haha
Old Nov 19, 2008 | 03:27 PM
hosspwr94's Avatar
I used a short piece of hose and just routed them together. But the plugged look is def cleaner looking!
Old Nov 19, 2008 | 05:00 PM
BUBBA's Avatar
Just curious: why would anyone living in Denver want to delete their heater.
Old Nov 19, 2008 | 05:16 PM
Angelis83LT's Avatar
Might have had a heater core burst, and it is his DD.
Old Nov 20, 2008 | 09:20 AM
BUBBA's Avatar
Good answer: why not just splice the inlet and outlet hoses together at the firewall. That way all you have to do is replace the core and re attach the hoses.
Old Nov 20, 2008 | 11:28 AM
Jazsun's Avatar
Hey, which hoses on the waterpump go to the heater core?
Old Nov 20, 2008 | 12:14 PM
sn8ke eatr's Avatar
the middle size ones lol
not the big main in/outlet hose for the radiator and not the little one that goes to the tb either.
if you look at your engine bay the heater core hoses run tucked along the fender along the pasenger side, the lines turn to metal. just follow the lines along to the wp
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
pologreen97z
Dec 2, 2014 10:42 AM
