Can I block off inlet and outlet for heater at the water pump?
I welded all of the outlets on my pump. Had the local speed shop do it, and he basically just drilled the pipe out and turned down a piece of aluminum to fit the hole and welded it in.
But i think the top oulet by the thermostat is a thermostat bypass so i've just been running a restrictor instead of a thermostat. It runs fine stays around 170-180 never hotter.
the middle size ones lol
not the big main in/outlet hose for the radiator and not the little one that goes to the tb either.
if you look at your engine bay the heater core hoses run tucked along the fender along the pasenger side, the lines turn to metal. just follow the lines along to the wp
stockssn2o
05-25-2015 08:54 AM
