Can a GM847 cam work with an a4?
Old Apr 7, 2004 | 03:50 AM
texasTA's Avatar
I am wanting to replace my Hotcam kit with a bigger cam and stronger valvetrain parts. Right now my car consists of ported heads, Electric H2O pump, Full exhaust (hooker lts, offroad ypipe, dual/dual), fully built tranny (hold 550 rwhp/rwtq) and a 2500 stall convertor.
So can I pull out the LT4 hotcam and run that cam on this setup without problems? This is a OBD1 1994 LT1 motor.
Old Apr 7, 2004 | 01:54 PM
texasTA's Avatar
Anyone know about this?
Old Apr 7, 2004 | 02:09 PM
95_LT1_6SPD's Avatar
I would want a bigger stall with that cam, probably 3000-3200. It will work with yours, but be more fun with a bigger one.
Old Apr 7, 2004 | 02:12 PM
texasTA's Avatar
yeah, i was already planning on stepping up to a Vig 3200 and 3.73 rear.
So, do you think this cam will pick up a lot of Hp/Tq over the LT4 hotcam?
Old Apr 7, 2004 | 02:15 PM
Yes, the cam is bigger in every aspect. Atljar made 35X rwhp with it on stock heads, so i could see 38X in it with good heads and a good tune.
Old Apr 7, 2004 | 02:17 PM
texasTA's Avatar
So if I was making 360rwhp with the Hotcam in the current setup, you think it should go up to about 38X with teh 847 cam?
Old Apr 7, 2004 | 11:49 PM
envme23's Avatar
what kind of heads are you running in your car
Old Apr 8, 2004 | 01:29 AM
texasTA's Avatar
Some lightly ported LT1 heads. The guy who did the cam install pulled them. He cleaned them and did a slight port/polish job on them. I plan on sending them off around the beginning of June to Lloyd Elliott ot let him hog them out.
Old Apr 8, 2004 | 02:01 AM
1994TransAm's Avatar
hey guy,
i'm running the 847 in my 94 lt1
level 2 trans from LT1 dave
3200 stall
lloyd elloit heads
1.5 rockers
LT's and hooker catback
3.73
30 SVO's
cai
PCM4LESS
i'm just finishing the install.... let you know how it goes
Old Apr 8, 2004 | 02:05 AM
texasTA's Avatar
Yeah definately let me know. I am running damn near the very same setup.
Race built a4 to hold 550rwhp/550rwtq
2500 stall (aobut to be a vig3200)
lloyd elliot heads
csi electric h20 pump
K&N FIPK
Hooker longtubes
offroad ypipe
1le elbow
pcmforless tuning
Old Apr 8, 2004 | 07:39 AM
Camaro_Maniac63's Avatar
You might have driveability issues with that cam. My buddy's car that ran a CC306, which is a slightly "smaller" cam, and a 2800 stall with ported stock heads wasn't too much fun to drive on the street as the engine would stall sometimes at a stop and that was with a mail order tune. Why would you that big on duration, anyways? I would look into a cam with a bit more moderate duration if you drive your car everyday. Good luck.
Old Apr 8, 2004 | 12:44 PM
texasTA's Avatar
okay, I see what you are saying. I have a local guy to tune/dynotune it, so I figured he could get the driveability issues taken care of. if you don't think this would be a good cam, what do your recommend for a big A4 cam?
Old Apr 8, 2004 | 02:44 PM
stik6shift93's Avatar
Fwiw you'll need a minimum of a 3500 stall with that cam, probably more like a 3800-4000 if you want to see it's full potential.
Old Apr 8, 2004 | 03:02 PM
WS Sick's Avatar
I'm using the cam in a 383 with a 3000 stall and 3.73s and a mail tune. It runs fine and never stalls.
rideordie
Nov 5, 2019 04:52 PM
LT14LIFE
Feb 9, 2015 09:35 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
