Can an EGR tube leak on an LT1 cause excessive oil consumption?
Old Sep 4, 2003 | 10:29 AM
Crazy Man's Avatar
Old Sep 4, 2003 | 10:50 AM
Hotwire's Avatar
sure it isn't the egr tube heating up the aluminum intake manifold causing it to expand and contract, breaking the seal between the intake and lifter valley, and sloshing oil out there? I've seen that a lot w/ the lt1s.
but as far as a tube leak causing oil consumption, I don't see how it could to be honest.
good luck.
Old Sep 4, 2003 | 11:37 AM
Crazy Man's Avatar
I did not notice any big leaks when i took the intake off.
There was a veryt small seeping but nowear enough to suck oil through. I have had to put in about 1 quart of oil every 1000miles or so at times. My combustion chambers, plugs and cylinder tops are black with oil deposits.
I have heard of that bad PVC valve may cause this also, but I can't see that either, but I have to ask the question.
I had this problem from day one , 3 years ago.
Great ARE LT1 stroker engines....
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
