can this be done
Old May 1, 2003 | 03:24 PM
MikeStank's Avatar
can this be done
Can i put the guages from a 97 firebird, the ones with the digital odometer into a 95?
Old May 1, 2003 | 09:45 PM
BOWTYDE's Avatar
Yes, but it would coat a ton of money. You would have to replace the enitre dash, along with the cluster and sending units.
Old May 2, 2003 | 12:18 AM
Fastbird93's Avatar
Not on the firebird. It's a direct swap so long as you use a 97 cluster. There's a guy on the speed density board that put one from a 97 into his 93, plug and play. If you use a 98+, the gauges will act funky. The camaro is the one that had the dash change, not the Firebirds. All you gotta do is find one from a 97, which isn't too common.
Old May 2, 2003 | 04:29 PM
MikeStank's Avatar
are you sure on this?
