can this be done
Not on the firebird. It's a direct swap so long as you use a 97 cluster. There's a guy on the speed density board that put one from a 97 into his 93, plug and play. If you use a 98+, the gauges will act funky. The camaro is the one that had the dash change, not the Firebirds. All you gotta do is find one from a 97, which isn't too common.
