can the cap be removed from the opti with it still on the car?
Old Jan 22, 2004 | 06:58 PM
Zack's Avatar
can I replaced the cap, with just the crank pully off? the pully is still on, so I cant see the opti too well. Also, can it be done with the WP still on?
Old Jan 22, 2004 | 07:05 PM
Red_94Formula's Avatar
yea im pretty sure once the balencer is off
Old Jan 22, 2004 | 07:58 PM
442olds's Avatar
you have to pull the water pump and the balancer off. If you can get the pully free of the hub, you don't have to pull the hub off the crank.
Old Jan 22, 2004 | 08:02 PM
IOW, the same stuff you would have to remove to replace the opti.
Old Jan 22, 2004 | 08:05 PM
well yea everything normally would have to come off to get it out but there a few less bolts to remove by leaving it on the motor. for those who are lazy like me will go all out for this!
Old Jan 22, 2004 | 08:11 PM
A few less bolts? You mean like 3? ...and those 3 are a lot easier to remove than taking the cap off. Not only that, it's usually much better to replace the whole thing, anyway.
Old Jan 22, 2004 | 08:16 PM
well yea... replace the whole thing those silly opticle sensors go all the time. might as well do it now or do it over later on
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
97SSdude
Dec 31, 2014 07:43 PM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
