Can anyone identify this injector?
Old Sep 5, 2004 | 08:44 PM
stew's94z's Avatar
Gentlemen, as the title states, does anyone know what type injector this is?
They were bought as Bosch 36#ers. The # on the injector reads 6053 17113798. The color is black and green and it has a small flat disc with 6 holes in the spray end.
Thanks, Dean
Old Sep 5, 2004 | 09:17 PM
n2oCamaro's Avatar
Re: Can anyone identify this injector?
www.witchhunter.com
Try this place. He was very helpful with mine. I had a similar problem. They almost sound like the injectors I have. Mine look like the stock injectors but had a serial number printed on them (17090304)
Old Sep 5, 2004 | 09:54 PM
stew's94z's Avatar
The GM Multec top feed Rochester/Delphi picture looks just like the ones I bought as Bosch 36#. Are they one and the same?
Thanks N2O, Dean
Old Sep 5, 2004 | 10:53 PM
Loadre's Avatar
sales@racetronix.com
Send them an email with the part number and they should be able to help you.
Black with a green cap sounds like Ford Motorsports 42#ers.
Old Sep 5, 2004 | 10:57 PM
Loadre's Avatar
Does it look like this?
http://www.fiveomotorsport.com/Parts...50558Green.jpg
Old Sep 5, 2004 | 11:48 PM
stew's94z's Avatar
The injectors have a black top and a green bottom. I'm pretty sure they are Multec Rochester because of the # 17113798 but I'm not 100% sure.
Anyone else want to take a guess?
Thanks,Dean
Old Sep 6, 2004 | 12:03 AM
Loadre's Avatar
The long number on the injector is sorta of just a build number. It should increase by 1 on each injector. The shorter number is the actual part number.
Old Sep 6, 2004 | 01:29 AM
stew's94z's Avatar
Oh, okay then the smaller # is 6053.
Thanks for your help.
Later, Dean
Old Sep 6, 2004 | 01:41 AM
EddieP's Avatar
Thanks N2O, Dean
No, the rochester injectors (GM/MSD/Holley) are not the same as bosch injectors (SVO).
Old Sep 6, 2004 | 01:54 AM
stew's94z's Avatar
Actually the point I was trying to make is that the picture looks just like the injectors I recieved. They are one and the same. The injectors I paid for are Bosch 36#'s. Which I don't think I recieved.
Later, Dean
Old Sep 6, 2004 | 09:35 AM
Loadre's Avatar
After checking racetronix's webpage they do have a couple injectors listed with 171137XX part numbers. So I guess that could be the part number. Just email them with both numbers and they'll help you. Sorry for the confusion. My Siemens injectors only had a 4 digit part #.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
