Can anyone guess my valve springs?
Old Jan 21, 2015 | 08:09 PM
Red_94Formula's Avatar
https://drive.google.com/file/d/0B4m...ew?usp=sharing
I got these LE3 heads. But I don't know what valve springs are on them. I don't think these came with the LE3 head package. I see three springs in there. The middle one being an odd flat spring. Any help would be great!
Looking to use Lunati 20080723 / 60123 SBC LT1, LT4 Hydraulic Roller Camshaft RPM Range 2800 - 6800 Lift .560"/.565" Dur.@.050 243/251 LSA/IAC 110/106 in a 385 with 12.1 static compression. Then add 1.6 rocker to get .597/.602. so im hoping these are hydraulic springs.
Derek
Old Jan 22, 2015 | 12:17 AM
Chimera96's Avatar
Re: Can anyone guess my valve springs?
Contact Lloyd, he may be able to identify from the pic
otherwise pull and measure open & close pressure at x.xx" installed height (assume 1.80"). measure for coil bind
if the springs spec out to whatever spring your cam card specs, than they would work.
need to confirm they can take the lift your cam makes with 1:6RR
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
