Can a 4L60E harness be spliced / soldered to work with a T56?
I'm trying to save some money here... no searches have helped.
A new M6 harness from gmpartsdirect is over $600. I haven't found any used. So I'm wondering if it's possible to cut and splice the wiring on my existing harness to make the thing work. Is it possible?
Certainly.
Here's the A4 to T56 conversion guide.
http://www.afrashteh.com/tranny_pics/T56.htm
You'll also need your PCM reprogrammed. I can help with that if you want.
