Can 30# SVO injectors be run with stock fuel pump?
Old Jun 17, 2004 | 09:33 AM
SLeePer350's Avatar
As the question says it ok to run the bigger injectors off of a stock pump? Will performance suffer, or is it actual dangerous to the fuel pump, etc....any ideas or experience with this matter?
thanks
Old Jun 17, 2004 | 10:12 AM
LPEdave's Avatar
It's not the size of the injectors, it's the amount of fuel you're using that's the question. I used the stock pump for 450hp, and I'm pretty sure other folks have used it quite a ways higher than that.
HTH
Dave
LWillmann's Avatar
Lots of people run 30 lb injectors on the stock pump with no problems.
HectorM52
Jul 30, 2017 11:46 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 04:58 PM
