Camshaft ?? For you Gurus!
Old Mar 23, 2005 | 10:43 AM
SiCXecutioNeR's Avatar
Hey all, I started my project on my 94 Z28, and I am totally new to internal engine, especially in the LT1... The Motor that Im using is the stock LT1, it has about 90K miles on it, runs really strong, uses no oil, and Im wondering what kind of cam to put in without major modification to the motor. I heard something about having to change the rockers on the heads? or something?! Please help me im lost!
Old Mar 23, 2005 | 10:51 AM
rskrause's Avatar
Moderator
Re: Camshaft ?? For you Gurus!
I don't think a cam swap is the place to get your feet wet. But FWIW, any cam worth swapping for will require new springs. And while you are at it, also swapping in a set of 1.6:1 roller rockers will help get the most out of the cam and can be done "incidently", you will be removing the rockers anyway to change out the springs.
The GM "hot cam" kit is a nice way to go. The cam works well with stock heads and programming and has all the major parts needed for a decent price (~$550).
GM's description: This off-highway hydraulic roller camshaft kit has the major valve train components to convert production LT1 engines from showroom stock racing, or hop up your small block Chevrolet V-8 that was originally equipped with a roller tappet camshaft. The 1.6 roller rockers, light weight valve spring caps, special designed valve springs and hot camshaft offers a significant gain in horsepower at a reasonable price. This kit includes the following items:
1 Camshaft (24502586)
16 Roller rocker arms (12370839)
16 Valve springs (12551483)
16 Valve caps (10212808)
16 Valve keys (24503856)
16 Valve spring shims (10212809)
Part Number: 12480002
Manufacturer: GM Performance Parts
Duration @ 0.050" Lift : 218/228
Valve Lift : .525"/.525"
Lobe Seperation Angle (LSA) : 112
Camshaft Type : Hydraulic roller LT4 Hot Cam
Rich
Old Mar 23, 2005 | 11:15 AM
raroz28's Avatar
Depends on what you want. Hot cam is weak, IMO.
http://www.cmotorsports.com/engine/l...ft-design.html
They have an awesome rep.
Old Mar 23, 2005 | 11:26 AM
SS MPSTR's Avatar
For an otherwise stock engine, the Hotcam is a reasonable choice and a proven & reliable performer.
Old Mar 23, 2005 | 11:52 AM
SStrokerAce's Avatar
HotCam is a good cheap choice for a cam swap. You can get really deep into it if you wanted to but the hotcam is a good way to go for you.
Bret
Old Mar 23, 2005 | 12:51 PM
Ken95Z28's Avatar
That was my first cam that I ever put into my motor, best bang for the buck. Stock heads, 3500 Stall Converter and my best time ever for that cam was in the 11.80's (low DA), but pretty much ran in the low 12's at my home track.
Old Mar 23, 2005 | 01:19 PM
1-bad-z28's Avatar
That kit is the best bang for the buck. The whole package for a little over $500. Nothing else out there can compare. It has a nice lope and some impressive hp/tq gains for that price. I would reccommend it to anyone who want a little extra. If you want major power, by all means, go out and spend $4000-$5000 or more.
Old Mar 23, 2005 | 01:20 PM
ChevyTuffD.A.'s Avatar
I vote for the Hotcam as well. If u want something a little bit bigger then check out the cc305.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
