Camshaft Swap. Am I Missing anything?
Old Sep 17, 2006 | 06:19 PM
CDN WS6's Avatar
Question Camshaft Swap. Am I Missing anything?
I'm in the process of gathering parts for an upcoming cam swap. Here's what I have so far.
Comp pro mag 1.6rr's nsa
ARP 7/16" rocker arm studs
Gm guideplates (8)
comp hi-tech pushrods 7.2"
comp 26918 springs, locks and retainers
comp 224/230 w/112lsa camshaft
LT4 ED timing set
Ford SVO 30lb injectors
BBk 52mm ThrottleBody
Thunder racing LT1 Camshaft swap gasket set
I will also be sending in my OBDI computer to madz28 for a tune. I will more than likely get a dyno tune next spring. Am I missing anything? Please let me know.
Old Sep 17, 2006 | 06:31 PM
JustNO's Avatar
Re: Camshaft Swap. Am I Missing anything?
Gm guideplates (8)
LT4 ED timing set
I think you should order a pushrod lenght checker first. then you should order the pushrods.
BTW I'm not sure, but maybe you will need LT4 camshaft swap gasket, not LT1. Again I'm not sure, because I don't know your rest setup.
Old Sep 17, 2006 | 06:38 PM
CDN WS6's Avatar
I will definately check pushrod length just to make sure. Also, the engine has no other mods. Unported heads and intake. Therefore, I figure the LT1 gaskets will work fine, won't they?
Old Sep 17, 2006 | 07:09 PM
seawolf06's Avatar
You'll only need LT4 gaskets if you have LT4 heads and intake. Why don't you get the Cloyes double roller timing set and a electric water pump? It's a much cheaper and heavier duty set and the ewp will give you 10 more hp/tq across the board.
Old Sep 17, 2006 | 07:19 PM
JoeliusZ28's Avatar
just curious, are different pushrods necessary to run the 224/230?
Old Sep 17, 2006 | 07:21 PM
seawolf06's Avatar
Pushrod checker is good to be perfect, but most people use stock length as long as the heads and block are all still stock and you're not using anything other than 1.5 or 1.6 rockers.
Old Sep 17, 2006 | 07:42 PM
kingman109's Avatar
stock length should be fine - my buddy through same cam and valvetrain in and we checked it out and the stock length was perfect.
other than that dont see anything off top of my head your missing besides of course fluids and misc tools to do the install.
ohh wait one crucial part your missing from the list.
BEER (of course only to be used as an anesthetic for the pain your knuckles will have)
Old Sep 17, 2006 | 10:21 PM
97formulakid's Avatar
sounds like a good list. I am thinking about tackling a cam swap on my car this winter and am either going with the same cam (224/230) or a 224/236.
93 RedBird
Nov 15, 2015 08:24 AM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Daluchman1974
Sep 11, 2015 06:12 AM
