Camshaft Break-in....
Old Mar 24, 2004 | 07:22 AM
Hawk350's Avatar
is there a breakin for a roller hydrolic? No need to use regular oil but synthetic>???
Old Mar 24, 2004 | 07:31 AM
ibanez6rg's Avatar
No need to break-in.
Old Mar 24, 2004 | 07:36 AM
Hawk350's Avatar
Just making sure, thanks!!!
Old Mar 24, 2004 | 10:47 AM
HungryT/A's Avatar
Yep, no break in. I would go easy on the car for the first 500 miles and then change oil, just to make sure I don't end up spinning a rod bearing...
Old Mar 24, 2004 | 10:55 AM
Hawk350's Avatar
Will do, thanks!!!
Old Mar 24, 2004 | 11:20 AM
rock1501's Avatar
I took mine to the track about an hour after it was installed.
I put 10k on it since then and everything is cool.
Old Mar 24, 2004 | 12:11 PM
mkent's Avatar
did you only pick up a little better than one-tenth of a second in the quarter mile after the cam install?
Old Mar 24, 2004 | 12:36 PM
rock1501's Avatar
The day I ran the 12.65 with boltons the DA was -1500ft and the temp was 30 degrees.My normal bolton times were 12.9@104
I would say I picked up a solid 3 tenths and with some tuning(car shifts at 5700 right now)with the stock tuning a 12.3 is possible
Old Mar 24, 2004 | 01:29 PM
Berly_BoneStock's Avatar
Standard breakin procedure.
Step 1 back out of your garage.
Step 2 DO A HELLA BURNOUT
Step 3 Cam is broke in
Old Mar 24, 2004 | 09:15 PM
mkent's Avatar
cool, i was gettin a little worried cause i'm finding this to be a lot of work to put this cam and headers on, i hope my car picks up more than that!
btw, i'm not saying you have bad times. i'm very impressed that you're running mid-12's with the stock heads. comparing to your bolt-on time, i expected more of a gain. sounds like a sweet ride though!
Old Mar 24, 2004 | 09:54 PM
My95Z's Avatar
drive around for a while, then change oil... broken in
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
