Camshaft bolt Stripped?? help please
Old Mar 22, 2003 | 01:26 PM
veryslowfbody's Avatar
I am in the middle of an optispark swap and the 3 bolts that you see right when you take the opti of are all loose(3 bolts that hold the cam in place i think). One was stripped and the other two are in bad shape. Can i just replace the two bolts in place without any problems??? I have had a bad metallic knocking noise and apparently i have found the source. Is this common someone please shed some light for me.
Old Mar 22, 2003 | 01:29 PM
RamAir95TA's Avatar
Are you talking about the three bolts that hold the camshaft sprocket to the cam? How did they come loose and/or stripped? If they break, you'd be in deep trouble. I'd recommend pulling off the timing cover and getting a better visual inspection of what's going on.
Old Mar 22, 2003 | 01:36 PM
Alright i will take off the timing cover and have a look. Yes i am referring to the 3 bolts that hold the cam sprocket on. I am about to take a trip to Lowes and see if they have the bolts that match.
Would i need to order those bolts from the factory??
Old Mar 22, 2003 | 02:46 PM
Bolt pn in this thread
http://web.camaross.com/forums/showt...threadid=96479
If you have stripped threads, you will have to heli-coil or get a new cam.
MadMav
May 25, 2015 09:35 PM
maybe2fast
Mar 16, 2015 09:45 AM
HCz28
Jan 11, 2015 11:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
