camshaft???
Old Dec 29, 2006 | 08:32 PM
edunegan95's Avatar
847 camshaft???
12370847 is this the 847 cam ya keep talkin about and how do you use it in lt1 s ?? i mean the long dowel pin for the opti how do fix that?
Old Dec 29, 2006 | 10:18 PM
Hard to figure out what you mean. ???
Old Dec 30, 2006 | 12:25 AM
seawolf06's Avatar
Call Crane Cams and they'll send you what you need.
Old Dec 30, 2006 | 12:44 AM
sssalah's Avatar
On an old GMPP parts catalog this number is listed as a generic hydraulic roller cam. I guess it has to be specified to the retailer about the pin required.
Old Dec 30, 2006 | 12:25 PM
edunegan95's Avatar
the 847 i found on sdpc2000 doesnt say u can use it in lt1s does it already have a long dowel pin for the opti or am i looking at the wrong one??
Old Dec 30, 2006 | 01:30 PM
Wild1's Avatar
Tell the cam company that you have an LT1 when you order the cam. They will install the correct pin for you. Too long and you will have an opti failure.
Be sure to measure the pin even if the cam company says it is correct. Save your original cam pin length to verify.
Old Dec 30, 2006 | 02:42 PM
seawolf06's Avatar
Crane cams now makes this cam. CALL THEM and tell them what year it's for and they should put the correct dowel pin in. Check shoebox's site to see what size you need and verify it with them. I would also measure it when you get it just to be sure.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
