cams and emissions
cams and emissions
What characteristics of a cam lead to producing more or less emissions? Is overlap the main factor? I'm sure head efficiency has a part to play. Can someone just give me a run down of how duration, lift, LSA, advance/retard and overlap effect emissions. Thank you!
try the search. there is alot about this. alot of people speculate about which cams will pass and which won't and why. i put in my 224/230 112 a little under two years ago with the hopes that it might pass. i'll find out this may. Either way i think a fifty doller bill should make most pass.
