Cams does it do this???
Old Oct 14, 2003 | 04:06 PM
dnz28's Avatar
After a before and after a tune my oil smells a little gassy. Does this happen to yours. Also sometimes when I rev the engine and stop then turn around to start it back up there is a grey smoke. I think its just unburned fuel but not sure. I have not cat so I see and smell everything. Come on give me something to worry about!!!
Old Oct 14, 2003 | 07:56 PM
Josh-'04 GTO's Avatar
Have you had the car dyno tested? Sounds rich to me. Get it on a wideband equipped dyno and find out for sure.
Old Oct 14, 2003 | 08:20 PM
Larnach's Avatar
Teacher teacher!
I've got a question... will a cam make the car rev a bit faster. I've got a bone stock car (torn apart of course) A4... adding ported heads, 230/236 cam, and a flywheel and clutch assembly thats about 25lbs lighter than stock.
Old Oct 14, 2003 | 08:21 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
The flywheel will make the rpm's rise and fall faster......the cam will allow you to rev higher so...............yes.
Chris
Old Oct 15, 2003 | 05:31 AM
QCKZ28's Avatar
i didnt think the stock flywheel weighs 25lbs.....what does it weight?
Jesse
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
