Cams for a 95 stock LT1 TA
Old Jan 28, 2005 | 12:51 AM
snakethis69's Avatar
Can some explain the 1.6 to me? about the cam. i was looking on speed inc to buy some and this is what i found,
93-97 LT1 CC1301-16 PRO MAGNUM NON-SELF ALIGNING 1.5 ROCKERS $259.99 Add
93-97 LT1 CC1302-16 PRO MAGNUM NON-SELF ALIGNING 1.6 ROCKERS $259.99 Add
what is the non- self aligning mean and what is the main diff between the 1.5 and the 1.6 and what is the advantage and what does the LT1 come with stock? What is the diff. between self aligning and non?
i also found this
93-97 LT1 CC073048 Nice upgrade from stock, excellent torque, good daily driver cam, stock computer Lift: .500/.510 Dur@.050: 210/220 LSA: 114
$239.99 Add
93-97 LT1 CC073058 Good cam for cars with bolt-ons Lift: .510/.510 Dur@.050: 220/230 LSA: 114
$239.99 Add
93-97 LT1 CC073068 Good mid-top end power cam, heads, intake and exhaust upgrades recommended Lift: .510/.540 Dur@.050: 230/244 LSA: 114
$239.99 Add
what is the Dur@.050 and the numbers?
Old Jan 28, 2005 | 12:57 AM
camarokid24's Avatar
Re: Cams for a 95 stock LT1 TA
From what I understand is the 1.6 roller rockersr are going to give a higher lift that the 1.5rr. I think (don't quote me ) the LT1 cam stock with 1.5 rr. Also the self aligning rr's dont reqire guide plates like the non ones
Old Jan 28, 2005 | 01:06 AM
the dur@.050 is duration at lift .050 (again don't " " me) Sounds to me like you need to call the place you are getting the cam spec info from so that they can give you all the info about what the sell and guide you with your decission making to what you want (Goals)
so if i go and buy a comp cam 1.6, what else do i need to get? i know push rods, rockers, and springs. i am looking to do this swap myself also so any tips and advice would be helpful
Old Jan 28, 2005 | 01:11 AM
well i have been looking around and i am not looking to buy till march, i basically want a good cam that will work with a stock setup right now but eventually if i get heads and i want it to be able to work with them. i might go FI down the road. i know that headers are also in the near future.
you mean the comp pro mags 1.6 ? they are the roller rockers
Old Jan 28, 2005 | 01:17 AM
Sounds like you are looking for a cam that is small but big enough to make good power with heads and also be a good blower cam for forced induction. I really wouldn't know what to recomed do a search you will find a ton of info about cam suggestion you would really need headers to take advatage of that cam.
Old Jan 28, 2005 | 01:18 AM
i dont know, i been looking on ebay and stuff for a good price, what does it mean "roller rockers" and the self aligning, what is the guide plate and what is it used for? i was looking on LS1 speed.com for cam setups. and i want and i want the 1.6, but i dont know what else i need. i mean i can order the cam itself easy, but what rods should i get and what rockers, do the rockers come with rods? and if i could i would like to find out a break down of a cam and find out what each part does if anyone has a link.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33624
like these rockers what do they do? would they work with any ol 1.6 cam?
what are the guide plates for, and what are the locks and retainers?
once i do it once, i know all these answers are going to come. cause i will know what i need once i take the stock setup apart.
Old Jan 28, 2005 | 01:22 AM
yea i know, headers are right after the cam, prolly with it. Marine Corps doesnt heap money into my hand.
Old Jan 28, 2005 | 01:29 AM
Try here they have part specific to camaro's
Old Jan 28, 2005 | 01:37 AM
those are cams and they work with 1.6 roller rockers. If I were you I would get a book about the internal combustion engine and study on what does what.
Old Jan 28, 2005 | 01:51 AM
redemn93's Avatar
well, for starters. the 1.6 is not a cam. thats the size of the roller rocker. get self alighning roller rocker with a 1.6 rating.
a good cam for what your looking for is the LT4 hotcam. found on almost any peformance parts website. there is a kit available which you will find easily that comes with a hotcam, roller rocker, springs, retainers, and almost everything youll need.
if you dont know what all these things are you might not want to try this yourself. a cam swap is not a small easy job. its a big one. especially if you dont know what your looking at. it requires an almost total break down of the motor and alot of the engine compartment. i dont mean to be rude but its not something you want to try if you really dont know much about it.
you almost will want to do a timing chain, and a few other maintanance things while your in there.
Old Jan 28, 2005 | 02:38 AM
I am going to have to agree it is a pretty big job that requires alot of time and research if you haven't done it before. You will need a good set of tools and some other specailty tools to do the job. Shoebox has a web page that has a cam install guide with pictures there you should be able to get an idea of what your in for.shoebox home page
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
GigaMp3z
Feb 20, 2003 02:57 PM
