cams?
Old May 9, 2010 | 11:41 AM
awill12's Avatar
cams?
i was wondering if some of you guys can tell me a little about the degrees and lobes on a an after market cam? Like what do they really mean? Whats the differents in a "street" , "strip" cam? What would be a good cam for a stock lt1? Should i get a hole kit roller rockers,springs(what spring load),lifters? lt4 kit?,trick flow? brand? Haha in other words just let me know what you guys are running thanks Also if i get a 58mm TB and long tube headers should i be sending my computer in? if so where to? thanks for the help
Old May 9, 2010 | 11:50 AM
Most cam manufacturers have comprehensive explanations/tutorials of cam numbers on their websites.
Cam choice is going to be governed by your goals and other supporting mods.
Old May 9, 2010 | 11:55 AM
awill12's Avatar
lookin for street,drag cam i guess. i like the real lobby sound at idel but still want enough vacuum for my brakes with out having to down shift all the time.
Old May 9, 2010 | 12:04 PM
RamAir95TA's Avatar
You've got quite a bit to learn. I'd take some serious time doing a search on this forum (and also others). There is a wealth of information out there that no one can fully post in one thread.
I'll probably get in trouble posting to another forum, but this is a good start:
http://www.ls1tech.com/forums/lt1-lt...ion-guide.html
Good luck!
Old May 9, 2010 | 12:05 PM
dangalla's Avatar
i was going to post that too, that is a great place to start
Old May 9, 2010 | 12:06 PM
n2ceptor's Avatar
Thousands of articles have been published... Research a few, not just one...
http://www.google.com/#hl=en&source=...cc9d2c9a111f92
Old May 9, 2010 | 12:16 PM
bubba4's Avatar
I'm sure you will get many responses to the question , be clear on your goal of what you want the car to do (how much drag and how much street). Streetability is defined by the driver so how fast do you want to go and what will it take to get you there. LF
Old May 9, 2010 | 12:27 PM
You could build a "strip" car that is barely driveable on the street, a "street" car that is slow at the track, or a 50/50 mix of both.
How often do you go to the track? Does your street driving include anything other than straight line, like aggressive driving through corners, mountain roads?
How far do you plan to take it? A good cam choice for stock heads may not be the best choice when you decide to go to ported stock or aftermarket heads?
What kind of HP are you looking for?
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
