This came out of my door... what is it?
Old Mar 8, 2004 | 11:19 AM
PsychoJavexx's Avatar
This coil looking thing, and a screw were sitting in my door, behind my door panel. What are these?
http://psychojavexx.cz28.com/
Old Mar 8, 2004 | 11:24 AM
HBHRacing's Avatar
Thats the coil spring that goes in between the window motor and reguator.. cant see hwta the other part is from that far away
Old Mar 8, 2004 | 11:39 AM
It's just a screw. How did that fall out, and does it hurt anything?
Old Mar 8, 2004 | 11:41 AM
HBHRacing's Avatar
something is wrong with your regulator. YOur gonna have to remove it and see if it broke. does the window still work?
Old Mar 8, 2004 | 11:57 AM
Yeah, the window still works. But it makes a horrible scraping noise. It's not hurting the glass, but it's scraping against something.
Old Mar 8, 2004 | 12:01 PM
HBHRacing's Avatar
ugh.. yeah. you will have to remove the motor and regulator so you can really see whats going on...
Old Mar 8, 2004 | 12:45 PM
Zerosheaven's Avatar
YOU ARE ALL WRONG!!! its the flux capacitor. im sorry buddy but your not travling in time anymore
Old Mar 8, 2004 | 12:55 PM
RE AND CHERYL's Avatar
Dude...I removed the flux capacitor from my car because it was giving me bad gas millage, and it dosn't look anything like that.
Looks like it's time to take apart the door.
Old Mar 8, 2004 | 04:42 PM
Try looking inside the door with an inspection mirror. Maybe the regulator blew up on someone else before you got the car and they replaced it, but left parts in the bottom of the door.
flat wound spring
Old Mar 8, 2004 | 04:44 PM
HBHRacing's Avatar
I thought about that as well, Thats why I asked him if it was working properly. Since he said it makes a bad noise I am willing to bet that it's from his regulator... but you never know
Old Mar 8, 2004 | 05:05 PM
Old Mar 8, 2004 | 05:52 PM
Yeah. I pulled my door panel off and stuck my head inside, and looked around. I saw where the flat wound spring is supposed to go, so I put it back on. The window still makes a terrible scraping noise, and when it goes all the way down, the spring falls off. There are a ton of small rivets and screws inside my door, but the window still works. I don't think I should be using it though..
Old Mar 8, 2004 | 06:05 PM
HBHRacing's Avatar
there has to be tention on it to stay in. thats why you will have to remove the motor to do it. Best thing to do it remove the whole regulator and see whats going on..
Old Mar 8, 2004 | 07:18 PM
Yeah, I suppose so. I'll just do it this weekend and look at that little guide shoebox left. Thanks a lot for the help.
camaro02DK
Jul 5, 2015 09:24 AM
MyfateZ28
Parts Wanted
Jun 20, 2015 11:02 PM
TobyZ28
Jun 26, 2012 10:58 AM
