camaro's with cast iron heads?
I have a buddy at work that bought a 96 Z28 and he said that it has cast iron heads. I got a chance to look at it and sure enough it does. I thought that all camaro's had aluminum heads? I told him that somebody probably put those heads on there or put a impala motor in it. How can we tell if it is a impala motor? Maybe some of you LT1 gures can chime in on this one.
thanks
Josh
thanks
Josh
If that is the case, your buddy has some decision making to do, as in, did he buy it from a dealer or private party? If it is from a dealer he can get his cash back in all cases if it was not disclosed that the motor was a 4.3l...
In case of a private party, he may also have a case for the same, but he would probably have to take the party to court to get resolution, as it was intentionally mis-represented...
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
