HVAC Delete
Old Dec 17, 2006 | 10:11 AM
93 4mula's Avatar
HVAC Delete
Well Im going to remove all HVAC today since I still have the motor out of my car. The lines that run from the heater core from the firewall to the water pump I think what do yall do about them since there will be no heater core anymore? Just loop them together at the waterpump?
Old Dec 17, 2006 | 10:47 AM
Dave89IROC's Avatar
yes, some have been ok plugging them, but I would loop them to be safe
Old Dec 17, 2006 | 04:13 PM
redneck01's Avatar
yea just did it friday..loop them.
Old Dec 17, 2006 | 04:25 PM
mdacton's Avatar
I took the tubes out tapped the holes and put pipe plugs in them
Old Dec 17, 2006 | 10:45 PM
93 4mula's Avatar
Well I removed it all out today. Really wasn't to hard of a job just really time consuming!! And man a bunchhhhh of screws.. But wow that was a lot of weight to come out and now there is soooo much space back there. Im actually thinking of hiding my 10lb nitrous bottle behind there haha
Old Dec 18, 2006 | 12:41 AM
93 4mula's Avatar
Oh and I got one question also. On the passenger side there was a black brain box that had a sticker on it that said something like pass key or something like that. What is that used for?
Old Dec 18, 2006 | 06:13 AM
Dave89IROC's Avatar
Anti-theft, that was the VATS module
Old Dec 18, 2006 | 07:04 AM
Mikes 1994 z28's Avatar
So did you end up pluging the two hoses or coupling them together?
Old Dec 18, 2006 | 07:19 PM
93 4mula's Avatar
Can I unplug that module and take it out or will I have problems? I have a 1993.
Old Dec 18, 2006 | 07:20 PM
93 4mula's Avatar
I just got a piece of hose long enough and tied it all together.
Old Dec 18, 2006 | 07:48 PM
Dave89IROC's Avatar
depends, do you have VATS tuned out of the computer?
Old Dec 18, 2006 | 08:22 PM
93 4mula's Avatar
Hmm. I dont remember if I did or not. So if I had it taken out then I can remove that module?
Old Dec 18, 2006 | 08:42 PM
Dave89IROC's Avatar
yes, will also need a simple rewire of a relay, then your good to go
Old Dec 19, 2006 | 02:02 AM
93 4mula's Avatar
What relay has to be rewired?
Old Dec 19, 2006 | 05:59 AM
Dave89IROC's Avatar
thefy deterant relay, which is also involved with the neutral safety switch
