camaro vs. cobra
Re: camaro vs. cobra
Originally Posted by MyZb383
But you also have to look at how flat and broad it makes power. 470 RWHP sounds really strong (and I respect those Cobras), but I'm betting that supercharged 4.6L doesn't have as broad of a power band as an LE2 does. Question is, what's the average HP over the powerband used while racing.
to beat a stock cobra you'll need about 340 to the wheels and the means to put it to the ground. how many are stock though?
to beat a modded one you're gonna need something with *****. think forged 355 with really good heads, ported intake, and a nice sized cam. even with all that you might be trapping 118-120. they'll trap 120 with ease. take some weight out too.
http://media.putfile.com/chad-vs-grape
that cobra was typically modded and look how close it was.
Thomas.
Originally Posted by mattybz28
my 396 LT1 on a 150 shot went 10.98 @ 126
he went 13.0@110 stock and mid 12's on sticky tires
what every one is saying is to beat a 03/04 cobra with a LT1 is you have to have more power than them...or have alot/alot/alot more mods than them.
Originally Posted by Chopstix
my buddie's 03 cobra w/basic bolt on's and a 50 shot went 11.01@130
You're pretty much gonna need a power adder if you're wanting to beat them without having something close to a built motor.
Just remember if you do the suspension right you can easily out 60ft a Cobra because of the IRS and not many swap to a solid.
Originally Posted by Kurt Crosbie
I thought that the sc cobra only came with 390fwhp.
I dont think a big shot of nitrous is required.. Heck, my bolt on car is running faster traps than stock cobras with a measly 100 shot.
Originally Posted by JakeRobb
It's going to take a lot of work to beat an 03/04 Cobra with an LT1, unless you're willing to go FI or a big shot of nitrous.
It can be done, but it's no trivial task. You're going to need about 400 rwhp to pull it off, and the suspension and tires to put that power on the ground.
Cobras are badass, but if you think about it, I dunno, they are pretty weak for a supercharged v8. Until you swap a pulley the size of a nickel on them, then they are really impressive, but aren't they in bolt on/geared LS1 area when stock?
ok so question continued from the other discussion. With my mods (CAI,3200 stall,high perf. tranny, full exhaust, chip, and gears) if and when i add the LE1 package and beef the suspension up a little, around how much RWHP and RWTQ would i be puttin out and most important would i be able to take a 03-04 cobra? thanks guys
Re: camaro vs. cobra continued
but the main question is how many times are you going to ask the same question???
http://web.camaross.com/forums/showthread.php?t=450323
http://web.camaross.com/forums/showthread.php?t=449987
