Are Camaro and Vette cyl. heads a direct swap?
Re: Are Camaro and Vette cyl. heads a direct swap?
well yeah...even the lt4s are direct bolt on...but you'll need the lt4 intake since the lt1 doesn't fit those heads.
but if they are identical..non-lt4...why would you wanna do it?
that's like swapping a stock cam for a brand new STOCK cam
Not if you want to keep your stock heads, and port/polish the hell out of the others.
Originally Posted by CARGASM
I have a a '94 Z and my friend has heads off a '95 or '96 Vette (I don't remember).
Are the a direct swap?
Yes, If it is a LT1
If they are LT4 you will need the intake as well
If swapping a used set, be sure to relocate the water temp sensor.
They are located on the pass side of the Vette & Driver side on a Camaro..... or swap sides (heads L to R) along with swapping the coolant transfer tubes & front coolant plugs instead. Not fun if you bolt them to the car before noticing this.
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Jul 4, 2005 05:00 PM
Chrisdude
Jul 24, 2002 02:25 PM
