Which cam will make more power; CC306 or the GM847?
Old Dec 28, 2006 | 11:35 AM
CALL911's Avatar
Which cam would make more power between the CC306 and the GM847? Would one make more than the other stock engine to stock engine and then be different when compared to a modded motor? Or will one make more power no matter what?
Old Dec 28, 2006 | 11:36 AM
speed_demon24's Avatar
Cc307
Old Dec 28, 2006 | 11:39 AM
CALL911's Avatar
Originally Posted by speed_demon24
Cc307
???.... Did you mean the CC306?
Old Dec 28, 2006 | 12:03 PM
jsetzer's Avatar
Short answer is the 847. But it wants to spin a bit higher too.
Of all the cams I have had, the cc306 was my favorite for just normal driving. It really didn't drive much different than stock. The 847 is a happy mix. It pulls harder up top and longer.
Old Dec 28, 2006 | 12:14 PM
CALL911's Avatar
[QUOTE=jsetzer;4307136]Short answer is the 847. But it wants to spin a bit higher too.QUOTE]
So, taking that into consideration, and say you had a motor that would support 7,000 RPM out of the two, which would make more power?
Still the 847?
Old Dec 28, 2006 | 12:28 PM
FryedClutch's Avatar
the 847 will have higher peak numbers
but when you talk about actually using it
if the motor can support 7grand the 847 will not run out of steam up there like the 306 will
so yes if your motor is built for high rpm 847 is def a better choice just choose gearing and or stall accordingly to help counteract the fact the 847 doesnt come alive till about 3 grand
Old Dec 28, 2006 | 12:53 PM
'94 Bad A Z28's Avatar
When I first got my car back on the road after my heads/cam (847) install, before my tranny went, from a 2nd gear roll if I stabbed the gass the car would spin and then hook (thank you BMR tubular adjustable TQArm) then around 4800RPMs the *** end would start to slide out that's how bad the car breaks loost at the TOP of 2nd gear! It's amazing, go for the 847 My car is set to shift at ~6950rpms and loves every bit of it.
Old Dec 28, 2006 | 12:58 PM
69gto96z's Avatar
The 847 will make more power, but from what I hear the 306 is a GREAT street cam that is fun to drive. I am doing a 306 and basic rebuild on my motor this summer.
Old Dec 28, 2006 | 01:00 PM
My 847 has great street behaviors, drives like stock to be honest.
Old Dec 28, 2006 | 01:12 PM
No.
Old Dec 28, 2006 | 02:37 PM
yeah when i had the 847 it was in a 6speed and it def didnt drive like stock
but i jave the 306 now and a superstreetfighter 3500 stall in an auto
and imo it drives like stock minus alittle bit of surgeishness at idle when its just barly rolling
but i still liked the 847 ALOT more than the 306
Old Dec 28, 2006 | 02:55 PM
jsetzer's Avatar
Ditto to what everyone is saying.
Its easier to spin the tires at the top of second than at the bottom.
The 847 needs a little beefier valve train (not much, but if you are a minimalist you need more)
For sure the 847 though.
I love my current setup, with the progressive controller dialed in it a blast even on the street with street tires. Its like the vtac kicks in.
Old Dec 28, 2006 | 03:03 PM
reamo04's Avatar
also check the XFI grinds, i believe the 468 is a great cam (if im thinking right)
have great street manners, and great power bands
Old Dec 29, 2006 | 09:55 AM
SStrokerAce's Avatar
847 = more peak HP
But both of them leave a lot on the table in the mid RPM range.
Bret
Old Dec 29, 2006 | 11:26 AM
jsetzer's Avatar
Originally Posted by SStrokerAce
847 = more peak HP
Bret
Although there is always the guy like me that doesn't listen, Ace is hinting that its better to have a custom one designed for your needs. (So ver true)
