Cam "walk-out" plate?
Cam "walk-out" plate? "shoebox again please"
Is it really needed on the Lt1? I mean the stub keeps the rear somewhat in check, (maybe more with a full dissy) and the opti should keep the front in check. Why can't be just junk the thing? Just wondering what you guys think about it.
Originally posted by Bone Daddy
What if you replace the roller with a hydraulic flat tappet cam?
Just found out all about the plate and an extensive lesson on roller vs. flat tappet.
You do not need the plate with a HFT cam, you do need it for a roller as the cam cannot move more that 5 thousandths either way. If you run a roller cam in an older block you have to use a cam button and a sturdy front cover. (depnds on block)
oldschool
Feb 9, 2016 09:21 PM
