cam and timing chain
Old Feb 14, 2006 | 08:21 PM
Demon's Camaro's Avatar
I have a 94z28 that has a bad shortblock currently(bearings). I am replacing it with another 94 block. I also have a 97 block that was from a complete motor that I had parted out. Would I be able to use the timing cover from the 97 block as part of the conversion to a vented optispark setup? I am doing a cc305 cam swap, so it will not be much of a hassel since the block is already out of the car.
If someone could give a part by part breakdown and prices or places that I could purchase these items it would be greatly appreciated. I know alot of people are doing the double roller but how much work is needed to change the cover?
I have read threads posted on this but still am unsure of how it will all come together sorry for my ignorance.
chris
Old Feb 14, 2006 | 08:35 PM
3gc's Avatar
3gc
Re: cam and timing chain
The cover from the 97 will have the crank position sensor hole. You need a timing cover from a 95.
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
