cam swap, something weird
Old Jul 30, 2007 | 09:35 PM
plaf713's Avatar
i swapped my old hot cam out for a new xfi cam and when i go to do the timing and line up the dots, i realized that the crank does not have a dot to line anything up to, whats going on here? anyone ever run into this problem?
thanks
paul lafreniere
Old Jul 30, 2007 | 10:02 PM
The crank gear has the dot, not the crank.
Old Jul 30, 2007 | 10:16 PM
plaf713's Avatar
thats what i meant, the crank gear. it has a dot but no on one of the teeth
Old Jul 30, 2007 | 10:36 PM
AZ2ENVY's Avatar
The crank gear and cam gear both have dots on them to line up .
Old Jul 30, 2007 | 10:44 PM
What timing set?
Old Jul 31, 2007 | 12:06 AM
SS RRR's Avatar
Possibly the wrong side facing out?
Old Jul 31, 2007 | 10:00 AM
plaf713's Avatar
the cam gear has a dot, the crank gear does not have a dot to line up with the crank gear. sorry for the confusion
Old Jul 31, 2007 | 04:27 PM
SS RRR's Avatar
You mean the crank gear doesn't have a dot to line up w/ the cam gear?
I know what you meant, but are you sure the crank timing gear has not been put on wrong?
Old Jul 31, 2007 | 05:03 PM
plaf713's Avatar
i dont know i didnt build the motor, i tired checking to see if there was a dot on the other side and there was nothing, im confused.
Old Jul 31, 2007 | 11:15 PM
Heatmaker's Avatar
Advanced Member
Don't the timing gears only go on a certain way? Isn't there a grove that aligns the gear properly? can't he use that to make a dot... or am I imagining things? it's been a while.
Old Jul 31, 2007 | 11:27 PM
I've never seen a gear without a marking. Something weird here.
Old Aug 1, 2007 | 12:00 AM
AZ2ENVY's Avatar
I think the crank gear was put on backwards brb with pic to show
what im talking about ....
chuyz28
Feb 19, 2015 12:50 AM
InfernalVortex
Jan 17, 2015 09:35 AM
chuyz28
Jan 15, 2015 04:14 PM
97z28k&N
Jan 9, 2015 04:58 AM
chuyz28
Nov 25, 2014 11:14 PM
