Cam Swap question..
Old Oct 4, 2006 | 08:07 PM
97BBlackZ's Avatar
Cam Swap question..
I plan on swaping the cam out in my car since the people that put it in ****ed it up and its making a problem.
To just remove the cam do i have to remove all the same stuff that i would be if i was changing out the springs and rockers to and why does it say to loosen the oil pan on shoebox's write-up?
Also why do you have to remove the intake to get the cam out? Can't you just loosen the rockers and rods since that is what is holding it in place?
Lastly, Should i replace it with the exact same cam with the exact same specs ect? Thinking it might cause bearing failure if it isn't replaced with the same thing although the engine doesn't have over 25k miles on it yet.
Old Oct 4, 2006 | 08:18 PM
Quickz1670's Avatar
Re: Cam Swap question..
What is the problem?
Loosen the rockers. Remove the pushrods. Remove the intake in order to take out the lifters. Loosening the oil pan makes it easier to remove/install the timing chain cover. I didn't loosen the pan and it was a pita to install.
If your not happy with the cam choice now's a good time to replace it. With low miles it would not hurt to put in a different cam.
Old Oct 4, 2006 | 08:25 PM
97BBlackZ's Avatar
The camshaft was not drilled for an opti.
I don't made what cam i have in there really. The one thats in there now was the same one i was going to go with on my old car so its all good.
I have to remove the radiator to right and the water pump for clearence?
Old Oct 4, 2006 | 08:32 PM
Quickz1670's Avatar
Yup
Old Oct 5, 2006 | 11:19 AM
Heatmaker's Avatar
Advanced Member
It's allot of work, and a good amount of time and money. You can't cut corners.
Heatmaker's Avatar
Advanced Member
Old Oct 5, 2006 | 11:53 AM
97BBlackZ's Avatar
I got the time part. Just not sure about the money part.
Old Oct 5, 2006 | 02:22 PM
seawolf06's Avatar
Make sure you allow for all the gaskets, lube, oil changes, RTV, etc. That's usually where people don't plan to spend as much money as they do. I also had to buy extra tools and even make some new ones since the LT1 is a breed all its own.
Old Oct 5, 2006 | 03:04 PM
You drop the front of the pan, because it goes on before the timing cover does. You cannot remove the cam with the lifters in and you must remove the intake to remove the lifters. Basically, you do everything that is in the write-up, though I know you like to do everything your own way.
A different cam is not going to make any difference with the bearings.
Old Oct 5, 2006 | 03:06 PM
Heatmaker's Avatar
Advanced Member
The area I spent the most money on, was unforseen things like specialty tools, sensors I found that needed to be replaced. And LT1 gaskets that I could only find at the dealer. OIL PAN gasket, sensor, definite.
jj_burchiel
Mar 5, 2015 07:05 AM
grabbem88
Feb 22, 2015 11:16 AM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
