cam swap problems
Old Mar 8, 2006 | 01:31 PM
  #16
Z95m6's Avatar
Re: cam swap problems
Originally Posted by TransAm396
its not "technically" a deathwish..I know PLEANTY of people who run with a stock chain with no problems (myself included)
Its not a bright idea especially when you have the stuff that he has.
Old Mar 8, 2006 | 01:41 PM
  #17
blkchevyz's Avatar
why? the stock timing chain really isnt that bad.
Old Mar 8, 2006 | 01:45 PM
  #18
jsetzer's Avatar
I wanted an electric water pump, so I went with a better timing chain. Thats not your problem though.
I say check rockers first, thats been my problem everytime I have swapped cams. Or it will start, pop a few times, then die. If you are using stock lifters I don't even bother with a special adjustment. I hand tighten all the locks, then turn the motor over a couple of bumps and hand tighten again. Then set them with it running.
Old Mar 8, 2006 | 01:49 PM
  #19
Z95m6's Avatar
The stock timing chain isnt that good. Do a search lots of people break them, hell some guy had an LE2 383 and broke a stocker on like his 2-3 wot run.
Old Mar 8, 2006 | 01:56 PM
  #20
blkchevyz's Avatar
theres probably a reason why it broke.
anyway i bet 95% of the head cam cars on this board are running stock timing chains.
hell im running a stock on my 420rwhp head cam and it see's 6500+ all the time.
i've went from the hot cam 50k miles, to the 306 80k to my current cam, 93k and no issue what so ever.
Old Mar 8, 2006 | 02:03 PM
  #21
Z95m6's Avatar
I think you're wrong most people are smart enough to upgrade their chain. A lot of people are running LT4 ED's or Cloyes double rolllers. I'd say over 50% of the guys here are running aftermarket it chains. You guys can do what you want but i wouldn't be risking my trick flow heads because of a stock chain.
Old Mar 8, 2006 | 02:22 PM
  #22
Cmr0z28's Avatar
The stock chain isn't even a chain...
Mine was so loose that we could almost pull the damn thing off, and that was with boltons/spray turning no more than 5800 RPMs.
Old Mar 8, 2006 | 04:12 PM
  #23
SC/TA's Avatar
Thanks for the info on the chains, but anyone have any info on why I am getting spark, and fuel and still not starting.
Old Mar 8, 2006 | 04:58 PM
  #24
turbo_Z's Avatar
Put the opti on wrong.
Old Mar 8, 2006 | 07:17 PM
  #25
Eddie Z-28's Avatar
Makes me glad I ordered an LT4 HD for my heads and cam setup.
Old Mar 8, 2006 | 11:28 PM
  #26
knta4dnu's Avatar
The opti can be installed wrong. My car would start but barely ran after cam install. My mechanic pulled and reinstalled the opti and it started right up and ran fine.
Old Mar 9, 2006 | 07:54 PM
  #27
jkucz31's Avatar
im having the same problem but with my hot cam install i had the car running and ran great but now nothing at all. starts just but just putters off really quick
Old Mar 9, 2006 | 07:56 PM
  #28
TransAm396's Avatar
...check your rockers..they might of came lose..today a week after i did it..i had to go back in and retighten them all..i didnt tighten the poly locks tight enough..i gave them a little tug. Now they are on there..but 3 rockers on the passenger side were lose..one of them was just about off..and 4 were loose on the driver side..now that I re lashed them...the car runs 10 times better.But I knew something was wrong..cuz at idle it didnt sound right....you could actually hear the valve not opening...
Old Mar 9, 2006 | 10:14 PM
  #29
tim95z28's Avatar
I guarantee you the opti is on wrong. I put mine on wrong. The people who say this is not possible are wrong! I think it depends on the length of your cam dowel. If you dowel is not as long, it can slip in to the other slots in the opti.
My car would not crank, some small pops. Pulled the opti and saw where the dowel had made a mark about 15 degrees off the correct hole. PUt it on correctly and fired right up.
I just put in a new cam, and I test fired it before I put the water pump on just to see if it woudl fire up.
Old Mar 9, 2006 | 10:17 PM
  #30
Z95m6's Avatar
Thats what i always do too. I put my opti on wrong during my motor install and spent half the day looking for the problem. Now when i have the opti off i install it and start the car first to make sure it runs before i slap it all back together.
chuyz28
Feb 19, 2015 12:50 AM
InfernalVortex
Jan 17, 2015 09:35 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
