cam swap problems
Re: cam swap problems
Originally Posted by TransAm396
its not "technically" a deathwish..I know PLEANTY of people who run with a stock chain with no problems (myself included)
I wanted an electric water pump, so I went with a better timing chain. Thats not your problem though.
I say check rockers first, thats been my problem everytime I have swapped cams. Or it will start, pop a few times, then die. If you are using stock lifters I don't even bother with a special adjustment. I hand tighten all the locks, then turn the motor over a couple of bumps and hand tighten again. Then set them with it running.
Originally Posted by Z95m6
The stock timing chain isnt that good. Do a search lots of people break them, hell some guy had an LE2 383 and broke a stocker on like his 2-3 wot run.
anyway i bet 95% of the head cam cars on this board are running stock timing chains.
hell im running a stock on my 420rwhp head cam and it see's 6500+ all the time.
i've went from the hot cam 50k miles, to the 306 80k to my current cam, 93k and no issue what so ever.
Originally Posted by blkchevyz
theres probably a reason why it broke.
...check your rockers..they might of came lose..today a week after i did it..i had to go back in and retighten them all..i didnt tighten the poly locks tight enough..i gave them a little tug. Now they are on there..but 3 rockers on the passenger side were lose..one of them was just about off..and 4 were loose on the driver side..now that I re lashed them...the car runs 10 times better.But I knew something was wrong..cuz at idle it didnt sound right....you could actually hear the valve not opening...
I guarantee you the opti is on wrong. I put mine on wrong. The people who say this is not possible are wrong! I think it depends on the length of your cam dowel. If you dowel is not as long, it can slip in to the other slots in the opti.
My car would not crank, some small pops. Pulled the opti and saw where the dowel had made a mark about 15 degrees off the correct hole. PUt it on correctly and fired right up.
I just put in a new cam, and I test fired it before I put the water pump on just to see if it woudl fire up.
