cam swap problems
Old Mar 5, 2006 | 08:26 PM
SC/TA's Avatar
cam swap problems
I just installed a new cam and heads. Now the car will not start. It seems like the timeing is out, but I really think I have the opti in right. the car cranks fast then real slow but it will not fire. any ideas
Old Mar 5, 2006 | 08:27 PM
Javier97Z28's Avatar
Moderator
Re: cam swap problems
Really could use some more info.
What year LT1, what setup, what timing chain.. etc
Rockers on too tight?
Old Mar 5, 2006 | 08:35 PM
SC/TA's Avatar
the car is a 95 lt1 stock bottom end. the timing chain was oem replacement. the cam is 224/234 and the heads are trickflow.
Old Mar 5, 2006 | 10:29 PM
silverlt1ss's Avatar
rocker arms to tight??? usally when it cranks fast the rocker arms are to tight and there keeping the valves open
Old Mar 5, 2006 | 10:49 PM
Moderator
Yah, I'm gonna go with rocker arms too tight. Start over on your lash.
Old Mar 5, 2006 | 10:59 PM
SC/TA's Avatar
Thanks guys, I will try the valves. this is my 1st cam swap on the lt1 engine. I have done several on other sbc but not the lt1. I was worried about the opti.
Old Mar 5, 2006 | 11:07 PM
Moderator
As far as the opti goes, as long as it sat in flush with the timing cover (ie, you didn't try to force it flush w/ the bolts), you should be OK.
The dowel pin can't go into the other slots on the opti unless you beat it on with a 2x4.
Old Mar 5, 2006 | 11:27 PM
SC/TA's Avatar
Thats what i thought about the opti. It went in smooth and flush. maybe its the valves. by the way, Javier you have a great website
Old Mar 6, 2006 | 01:50 PM
SC/TA's Avatar
I adjusted the valves again, still no start. any other ideas
Old Mar 6, 2006 | 01:55 PM
SC/TA's Avatar
I am also getting a code 21. I dont know if that would cause it not to start though.
Old Mar 7, 2006 | 03:11 PM
SC/TA's Avatar
I MAY have found the problem, the clip that holds the wiring harness to the opti is broken off. Maybe its not making a good connecton. What do you guys think? I went ahead and ordered a new one, but its going to take about a week to get it. So I wont be able to even see if thats the problem untill I get it.
Old Mar 8, 2006 | 12:56 PM
SC/TA's Avatar
Any opinions on this being my problem?
Old Mar 8, 2006 | 01:00 PM
Cmr0z28's Avatar
I haven't seen an opti harness that ISN'T cracked...mine is pretty much destroyed and Javier's is cracked too. I ordered one last Monday and it still hasn't arrived!
It's definitely a possibility...
Old Mar 8, 2006 | 01:09 PM
Z95m6's Avatar
call me crazy but i think you're going to end up spending a lot of money real quick if you get that thing runnning. A stock timing chain, with a heads, cam and SC motor is just a deathwish.
Old Mar 8, 2006 | 01:29 PM
TransAm396's Avatar
its not "technically" a deathwish..I know PLEANTY of people who run with a stock chain with no problems (myself included)
